Hi everyone,
I’m working on a new electronics project and could use some advice on selecting the right microcontroller. I need a versatile and reliable microcontroller for a project that involves controlling sensors, motors, and communication via UART and SPI.
The requirements are:
Low power consumption for battery operation
Multiple I/O pins (at least 10-15)
Good support for libraries and a strong developer community (since I'm not an expert)
Compatibility with Arduino IDE or any similar simple development environment
Preferably something cost-effective, since it's a hobby project ragdoll hit
I’ve been looking at options like the Arduino Uno and ESP32, but I’m not sure which would be better suited for my needs, or if there’s another microcontroller you’d recommend.
Has anyone used these, or do you have any other suggestions? Also, are there any common pitfalls I should watch out for when working with these types of microcontrollers?
Any advice would be greatly appreciated!
Thanks in advance!
The ESP32 is a great choice for your project due to its low power consumption, ample GPIO pins, and support for UART, SPI, Wi-Fi, and Bluetooth. It has a strong developer community and is compatible with the Arduino IDE. While the Arduino Uno is simpler, it might be limiting for more complex tasks. Just ensure compatibility with your components, as ESP32 operates at 3.3V logic.
a little to the left
